Hello,
Plugged my stick Tstick+ terratec on my vu+ uno (2.0.6 rev c) and no luck : stick recognized but scanning auto (tried all dvb-t settings: europe, iceland, austria) found no channels.
By the way, my elgato dtt dvb stick works on the same configuration with the same antenna.
The same stick works on linux (kernel 3.9, ubuntu) and windows.
Do someboy has the same stick and have it working on a vu+ uno ?
Thanks.
an extract of the dmesg command below:
fpga update driver loaded
udevd (118): /proc/118/oom_adj is deprecated, please use /proc/118/oom_score_adj instead.
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
Custom Black Hole build
usbcore: registered new interface driver dvb_usb_rtl28xxu
usb 1-1: dvb_usb_v2: found a 'TerraTec Cinergy T Stick+' in warm state
usb 1-1: dvb_usb_v2: will pass the complete MPEG2 transport stream to the software demuxer
DVB: registering new adapter (TerraTec Cinergy T Stick+)
usb 1-1: DVB: registering adapter 1 frontend 0 (Realtek RTL2832 (DVB-T))...
i2c i2c-4: e4000: Elonics E4000 successfully identified
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1 2 0
usb 1-1: dvb_usb_v2: 'TerraTec Cinergy T Stick+' successfully initialized and connected
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
EXT3-fs (sda1): error: couldn't mount because of unsupported optional features (240)
EXT2-fs (sda1): error: couldn't mount because of unsupported optional features (244)
EXT4-fs (sda1): recovery complete
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0
bcm7413: hotplug_callback():
Hotplug - status.connected 0
Adding 262140k swap on /hdd/swapfile. Priority:-1 extents:2 across:270332k
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xe
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
svc: failed to register lockdv1 RPC service (errno 124).
DVB: registering adapter 0 frontend 0 (Realtek RTL2832 (DVB-T))...
Thanks.
Use it with care.
