I have the Duo2 with a twin-tuner and a single tuner with loopthrough.The twin-tuner is connected to separate feeds from a single sat (28e) setup, the single tuner connected to a 4 Sat DISEQC switch.
I have an issue where the loopthrough doesn't work until that tuner has been in use, once it has been used, then the loopthrough works until the box reboots. It also does not work when a recording is playing. I had previously used this tuner in an Ultimo and loopthrough worked OK on that even when playing a recording.
Anyone else noticed this or is there a trick setting I've missed somewhere? using 2.0.5B
