Uno 4K, Uno 4K SE, Zero 4K and DTT/TDT/DVB-T usb tuners on BlackHole
@nunigaia
Latest OpenBlackHole can run my PCTV 292e DVB-T2 stick if i install driver from feeds.
But regular BlackHole 3.0.9. cannot see this device.
Can you provide, what to install from telnet. Key devices of PCTV 292e stick are:
Empia EM28178 Silicon Labs Si2168 Silicon Labs Si2157
Is it possible to copy files (drivers) from latest OpenBlackHole to standard BlackHole to get this DVB-t2 stick working?
ciao a tutti, intanto grazie per la lista dei chips compatibili.
Qualche buon samaritano avrebbe anche una lista dei relative marche e modello in vendita con tuner usb dvb-t2?
E poi una conferma: vi risulta che ,nonostante sia scritto a caratteri cubitali sulla scocca del tuner stesso, la Astrometa con chip RTL2832, in realtà non sia dvb-t2 ma semplicemente una dvb-t?
How to install a driver for usb-t2 HiVision HU472-DC, vendor 1b80:d3v2 rev.40.01. the driver found here
how to install it? help.
Thank you!
Some like per example:
  • Vuplus Turbo tuner
  • Xbox One tuner
Note: I am referring this ones, because i own both ( 2 turbos and 2 Xbox tuners ).
Not the Vuplus Turbo SE, no support as it looks like because it can't be found. The shops has switched to the newer SE model now.
Have made a topic about my problem with the SE tuner.
