Unstable xbmc
paulus22
My xbmc (BH2.1.7.1) is very unstable, locks up, unresponsive remote and requires a full power cycle to recover. I wonder whether anyone understands the log file (attached) and can give me a clue as to what is causing my instability.
Thanks in advance.
  • xbmc.zip
Moderator
Thanks in advance.
The problem i think is this:
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named pkgutil
File "/media/hdd/.xbmc/addons/plugin.video.genesis/default.py", line 343, in <module>
from resources.lib.sources import sources
File "/media/hdd/.xbmc/addons/plugin.video.genesis/resources/lib/sources/__init__.py", line 22, in <module>
import sys,pkgutil,re,json,urllib,urlparse,datetime,time
ImportError: No module named pkgutil
paulus22
Great. Where will I find the pkgutil.ipk that fits with BH/xbmc? I found python-pkgutil_2.7.2-r2.18-dream2_mips32el.ipk - but not sure that is the correct version?
paulus22
Thanks nunigaia, from my log you have identified the module that you suspected was missing from my previous topic. My problem is that I am unfamiliar with -ssh sessions (wouldn't know where to start) but can easily install ipk's. So I am looking for the correct ipk to install via a method I understand. Hope this makes sense.
Moderator
If you install DCC ( Dreambox Control Center ) it´s very simple ... you just need to enter telnet ... and enter the appropriate commands.
The commands ... you know it, because i told you ... it´s so simple ...
