It is better Iam told to have the epg on an external drive to reduce unnessasory moment of the HD which can produce heat !Your correct about putting the picons on usb but not the epg put this on the Hard drive
Thank you kingy29 do have any practical tips to keep your systems running longer please post here!That is not correct epg is loaded into memory when enigma is started save epg backup to HD
