starchaser
Ciao
I have a Vu+ Solo2 with BH 2.1.3 installed.
With the Sky DVB-T USB Tuner I see all the channels but most of the Mediaset channels (while it works perfectly when I plug it on the TV). The signal rate go to 0% (sometime blinks to hgher values but then it goes back to 0% immediately after).
To try to fix the problem I first bought a LTE Filter (as suggest is some posts here) but it did not work. I had same issue as above.
Then I bought a different USB Tuner, a DVB-T2 (a white labeled DVB-T2 USB TV Stick HD-901T2), but apparently this second Tuner is not supported (it is recognize by the Vu+ as a DVB-T2 tuner but it doesn't work, as no channels are shown).
Please, can you help ?
Thanks
Thanks
