USB DVB-T Tuner on Vu Solo Se
Search40
Tonight tried PCTV Nano Stick DVB-T2 290e on Vu Solo Se, it come up with Dummy Tuner, does this mean that above tuner is not supported, or maybe to early for this box to use USB-Tuners?, no Drivers YET?Thanks!!
angelofsky1980
BlackHole Driver Specialist
I've tested the PCTV 290e into SoloSE box and was correctly detected and tunes.
BH image of course.
angelofsky1980
When did you tested?, because last night was not working, tested with Black Hole Image, it is only one image only at the moment!
I haven't IT913x devices but I've tested a lot of other devices (DVB-T/T2). I've read your log posted above and your device is correctly detected.
Report the output of the command below:
usbtuner -V
Search40
I see ok, this USB was not mine just tested last night, i do not have now the usb, returned to the person i got it from, but it was detected as dummy tuner, please trust me 100%, i am re seller, i have tested lot of satellite receivers usb etc, now could you please tell me which usb dvb-t tuner you tested with vu solo se, and worked 100%, dvb-t2, and dvb-t, please write here all the models, as i am thinking to buy one, thanks!!
