usb-gp8psk
ReeLMAn
Tuner will not lock on any of the transponders .Signal is constantly moving up and down in mean time tuner works with my dm800se
Here is my output Text document
Many Thx
  • output.txt
ReeLMAn
I test mostly all Vu+Duo2 images on the net none of them work with usb tuner gp8psk..I think has to do with Enigma2.Working well with tuner A or B Signal will lock on all transponders signal is 100 present same as with dm800se.I am puzzled :wallbash:
ReeLMAn
Question
When using Black hole image signal on usb tuner is barely 3 to 5 preset and still tuner will lock but not all the time .This is happening with all VU duo+2 images out there at the moment except VTI image signal shows exactly as i have 90 present to 100 and tuner locks instantly . What seams to be the problem ?
