USB HDTV DVB-T tuner
nantoniou
Can someone please suggest a good, reliable and tested usb DVB-T tuner that supports HDTV also for VU+ Duo?
And maybe a suggestion regarding to where to buy online?
Thanks in advance!
angelofsky1980
BlackHole Driver Specialist
Thanks in advance!
All USB DVB-T tuners supports HD transmissions.
The only exception is the experimental DVB-T2 transmissions in UK.
There are good devices like Avermedia A867, Pinnacle PCTV 74e and others.
nantoniou
OK. I did a little search and I came up with 2 possibilities (I assume that they are both MPEG-4 - correct me if I am making a mistake):
1. AVERMEDIA USB DVB-T AVerTV Volar HD A835 (http://www.pixmania.com.cy/cy/gr/04824462/art/avermedia/Κλειδι-usb-dvb-t-avertv-volar-hd-a835.html)
2. PCTV SYSTEMS USB key PCTV nanoStick Solo Sports (http://www.pixmania.com.cy/cy/gr/09607057/art/pctv-systems/usb-key-pctv-nanostick-solo-sports.html)
They are both priced at 23.90 euro plus shipping.
Since, I have no experience at all regarding this issue, does anyone have any suggestion as to which one will work better?
Thanks again!
nantoniou
Dear blackspawn2,
I followed your suggestion and bought Avermedia A867. I received it yesterday and I immediately installed it. It works perfectly! Thanks for your suggestion.
mgalins
Hi!
Not necessary you should buy so expensive with advanced remote control, which you will never use. 2 weeks ago I did put on Duo2 this one:
http://www.ebay.co.uk/itm/USB-DVB-T-RTL-SDR-Realtek-RTL2832U-R820T-Tuner-Receiver-Dongle-PAL-IEC-Input-/310793632621?pt=UK_Computing_Video_Capture_TV_Tuner_Cards&hash=item485cbe7b6d
Works perfectly fine!
Palinkat
I got this one based on feedback from this forum
http://www.ebay.it/itm/DIGITAL-KEY-AVERMEDIA-A867-LED-BLU-DIGITALE-TERRESTRE-ANCHE-X-PC-MAC-DREAMBOX-/121237659218?pt=Decoder_Satellitari_e_Digitali_Terrestri&hash=item1c3a53de52
It works very well on both duo and duo2
ascige
Thanks all.
Today afternoon AverMedia arrive! I have already tested and it works perfectly fine! Thanks to mgalins and thanks also to Palinkat. I think that I'll buy also Realtek tuner receiver. It's very convenient.
skimitchell
Hi guys,
I purchased a AVerMedia AVerTV Volar HD Nano Digital TV Tuner USB Capture DVB-T Remote A867R for my Vu+ Duo running latest Black Hole image.
I can get terrestrial channels however they are pixelated and not good enough to watch. I have checked cables and all setting with no improvement.
The cable directly into the TV is perfect.
Do you think its a driver issue?
Thanks in advance.
Justin
paolino
Vu+ User+++
@skimitchell : You can't compare TV tuner to USB DVB-T tuner. Sensibility is different.
My list of selected tuners from best to worth : 1. WinTV-Nova-T 2. Astrometa DVBT/T2/C DAB FM (only DVB-T on Linux) 3. Fujitsu Siemens Zarlink MT-352 chip 4. LV5T Deluxe
skimitchell
So you saying that my tuner may never function correctly. Gutted as i read on a forum that it worked perfectly on same box.
Do you know where to purchase WinTV-Nova-T in Australia?
Thanks for your help.
