USB Tuner PCTV 520e
sharky
Hi,
I have BH 1.7.9 on a VU+uno
UsbTuner v0.3.12
I try plug an USB tuner PCTVSystems QuatroStick-nano 520e
In this web site
http://www.linuxtv.org/wiki/index.php/PCTVSystems_QuatroStick-nano_520e
it explains how to install the driver
1. I placed the file dvb-demod-drxk pctv.fw-in / lib / firmware Rights 644
2. Apply this patch
http://patchwork.linuxtv.org/patch/10404/
but how ??
I have try copy to /tmp/ and
root@vuuno:~# patch -p1 < /tmp/1-2-get_dvb_firmware-add-dvb-demod-drxk-pctv.fw.p
atch
patching file Documentation/dvb/get_dvb_firmware
patch: bad src file
not wok!!
Thanks for your support
angelofsky1980
BlackHole Driver Specialist
Hi,
UsbTuner v0.3.12
In this web site
2. Apply this patch
but how ??
atch
patch: bad src file
not wok!!
First of all you are doing some thing wrong.
The installation of firmware file is correct but not the rest of the post because is related to SOURCE files and not the kernel objects compiled for Linux boxes.
Plug your device and send the command
dmesg
at the end of the long output you should see something related to DVB subsystem: post it here. Your device should be already supported by BH 1.7.9 series.
sharky
Thank you to answer me
I made ​​the second point because I still could not see my usb tuner
See dmesg
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO        or FUA
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=15142200
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 3.2 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan:  mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table Bbt0 found at page 0000ffc0, version 0x01 for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0x01 for chip on CS0
nand_read_bbt: Bad block at 0x02f20000
nand_read_bbt: Bad block at 0x062a0000
Creating 8 MTD partitions on "brcmnand.0":
0x000000000000-0x000007200000 : "rootfs"
0x000007200000-0x000007600000 : "kernel"
0x000007600000-0x000007a00000 : "boot"
0x000007a00000-0x000007c00000 : "splash"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
sda: sda1
UBI: attaching mtd0 to ubi0
sd 0:0:0:0: [sda] Attached SCSI disk
UBI: physical eraseblock size:  131072 bytes (128 KiB)
UBI: logical eraseblock size:    126976 bytes
UBI: smallest flash I/O unit:    2048
UBI: VID header offset:          2048 (aligned 2048)
UBI: data offset:                4096
ata2: SATA link down (SStatus 4 SControl 300)
UBI: max. sequence number:      1050
UBI: attached mtd0 to ubi0
UBI: MTD device name:            "rootfs"
UBI: MTD device size:            114 MiB
UBI: number of good PEBs:        910
UBI: number of bad PEBs:        2
UBI: number of corrupted PEBs:  0
UBI: max. allowed volumes:      128
UBI: wear-leveling threshold:    4096
UBI: number of internal volumes: 1
UBI: number of user volumes:    1
UBI: available PEBs:            0
UBI: total number of reserved PEBs: 910
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 7/1
UBI: image sequence number:  40675335
UBI: background thread "ubi_bgt0d" started, PID 47
UBIFS: parse sync
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size:  112500736 bytes (109864 KiB, 107 MiB, 886 LEBs)
UBIFS: journal size:      9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format:      w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root:  0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 244k freed
NET: Registered protocol family 10
rtw driver version=v3.4.4_xxxx.20120730
Build at: Dec  3 2012 17:11:41
usbcore: registered new interface driver rtl8192cu
procmk_init
dvb_bcm7413: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (vuuno)
enable MII = 0
NEXUS_Frontend_GetUserParameters 0 0
bcm7413: hotplug_callback():
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xe
[GPIO]Default
[GPIO]RST Default
[GPIO]fpga secu
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[VID]: <6>bcm7335_video_init
[AUD]: <6>bcm7335_audio_init
DVB: registering adapter 0 frontend 0 (Vuplus FE)...
bcm7413: bcm7335_frontend_init(): vtuner1 : 2
[MPVR]: >> misc_pvr_init
input: dreambox advanced remote control (native) as /devices/virtual/input/input        0
[LCD]: registered
[CI]:0 1
[CI]: registered ci0 0
[CI]: registered ci1 0
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
udevd (105): /proc/105/oom_adj is deprecated, please use /proc/105/oom_score_adj        instead.
kjournald starting.  Commit interval 5 seconds
EXT3-fs (sda1): using internal journal
EXT3-fs (sda1): mounted filesystem with writeback data mode
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1  2 0
[VID]: VIDEO_CONTINUE 1  1
[VID]: VIDEO_CLEAR_BUFFER 1  1 0
[VID]: VIDEO_STOP 0  1
[VID]: VIDEO_SELECT_SOURCE 0
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
svc: failed to register lockdv1 RPC service (errno 124).
[LCD]: unknown cmd 0x1015
[CI]:ci_dev_open
[CI]:entering.. A NEXUS_DvbCi_Open
[CI]:NEXUS_DvbCi_Open done..
[CI]:Installing callbacks
[CI]:Forcing card check
[CI]:Card insertion status changed
[CI]:entering.. B NEXUS_DvbCi_Open
[CI]:Card B insertion status changed
[CI]: CI interface initialised
[CI]:ci1_dev_open
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -839115280
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
FE tune c
[AUD]: AUDIO_SET_BYPASS_MODE 0
[AUD]: AC3 proc_get_ac3 0  audio_passthrough_spdif : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[VID]: VIDEO_SET_STREAMTYPE 1
[VID]: VIDEO_FREEZE 1  0
[VID]: VIDEO_PLAY 1  5 2
[VID]: VIDEO_SLOWMOTION 0    1
[VID]: VIDEO_FAST_FORWARD 0    1
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xe0db4f54
[AUD]: setting mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
usb 1-2: new high speed USB device number 2 using ehci-brcm
Linux video capture interface: v2.00
WARNING: You are using an experimental version of the media stack.
        As the driver is backported to an older kernel, it doesn't offer
        enough quality for its usage in production.
        Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
        Custom Black Hole build
em28xx: New device PCTV Systems PCTV 520e @ 480 Mbps (2013:0251, interface 0, cl        ass 0)
em28xx: Audio Vendor Class interface 0 found
em28xx: Video interface 0 found
em28xx: DVB interface 0 found
em28xx #0: chip ID is em2884
em28xx #0: Identified as PCTV QuatroStick nano (520e) (card=86)
em28xx #0: Config register raw data: 0x24
em28xx #0: I2S Audio (3 sample rates)
em28xx #0: No AC97 audio processor
em28xx #0: v4l2 driver version 0.1.3
em28xx #0: V4L2 video device registered as video0
usbcore: registered new interface driver em28xx
        Use it with care.
drxk: frontend initialized.
drxk: status = 0x639260d9
drxk: detected a drx-3926k, spin A3, xtal 20.250 MHz
tda18271 4-0060: creating new instance
DRXK driver version 0.9.4300
tda18271_read_regs: [4-0060|M] ERROR: i2c_transfer returned: -19
Unknown device (16) detected @ 4-0060, device not supported.
tda18271_attach: [4-0060|M] error -22 on line 1274
tda18271 4-0060: destroying instance
Em28xx: Initialized (Em28xx dvb Extension) extension
        Use it with care.
IR keymap rc-pinnacle-pctv-hd not found
Registered IR keymap rc-empty
input: em28xx IR (em28xx #0) as /devices/platform/ehci-brcm.0/usb1/1-2/bh-rc/rc0        /input1
rc0: em28xx IR (em28xx #0) as /devices/platform/ehci-brcm.0/usb1/1-2/bh-rc/rc0
Em28xx: Initialized (Em28xx Input Extension) extension
root@vuuno:~#
angelofsky1980
See dmesg
sda: sda1
UBIFS: parse sync
procmk_init
enable MII = 0
[GPIO]Default
[GPIO]RST Default
[GPIO]fpga secu
[GP]:brcm_pwm_init
[LCD]: registered
[CI]:0 1
[CI]:ci_dev_open
[CI]:ci1_dev_open
FE tune c
        Use it with care.
        Use it with care.
        Use it with care.
root@vuuno:~#
You are wrong.
The device is currently detected by Vu+ box but doesen't work correctly:
        Use it with care.
        Use it with care.
        Use it with care.
This block describe the detects of your USB DVB device and show some problems on it and these infos are very useful.
sharky
Why am I wrong? it does not work! :D
With the log, I saw it was detected and there were errors.
For cons, I do not understand it.
I'm glad this info useful to you.
Does it solve my problem?
Can you tell me more? :oops:
sharky
Hello,
I have a new vu + uno. I'm sure the tuner is not working properly. I think it has frequencies that do not. I'd really like to run the second tuner for show and prove.
thank you for your help.
angelofsky1980
Hello,
I think with new BH you can use your tuner ....
sharky
After plug: green screen :fie:
I have not push de .fw file ...
PS: where i can help the transaltion, my mothertong is french ... and the french is not great
sharky
BH 2.0 REV A
Not show my tuner but no error
How i can switch tuner ?
see dmesg
input: dreambox advanced remote control (native) as /devices/virtual/input/input0
[LCD]: registered
[CI]:0 1
udevd (119): /proc/119/oom_adj is deprecated, please use /proc/119/oom_score_adj instead.
[CI]:ci_dev_open
[CI]:ci1_dev_open
[AUD]: AUDIO_SET_MIXER -840098328
bcmemac: eth0 NIC Link is Down
[CI]:ci_dev_open
[CI]:ci1_dev_open
[AUD]: AUDIO_SET_MIXER -850534936
bcmemac: eth0 NIC Link is Up 100 Mbps Full Duplex
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
eth0: no IPv6 routers present
[CI]:ci_dev_open
[CI]:ci1_dev_open
[AUD]: AUDIO_SET_MIXER -840475160
FE tune c
[AUD]: AUDIO_SET_BYPASS_MODE 1
[AUD]: proc_get_ac3 0 audio_passthrough_spdif : 0
[VID]: VIDEO_PLAY 1  2 2
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xe0da9f54
[VID]: VIDEO_STOP 1  1
[AUD]: AUDIO_STOP 1
[AUD]: AUDIO_CONTINUE 1 0 audio pid_hndl : 0x0
[AUD]: AUDIO_CONTINUE:bcm7335->audio_pid_hndl is null 0 0
FE tune c
FE tune c
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
        Use it with care.
em28xx: New device PCTV Systems PCTV 520e @ 480 Mbps (2013:0251, interface 0, class 0)
em28xx: Audio interface 0 found (Vendor Class)
em28xx: Video interface 0 found: isoc
em28xx: DVB interface 0 found: isoc
em28xx: chip ID is em2884
em2884 #0: Identified as PCTV QuatroStick nano (520e) (card=86)
em2884 #0: Config register raw data: 0x24
em2884 #0: I2S Audio (3 sample rates)
em2884 #0: No AC97 audio processor
em2884 #0: v4l2 driver version 0.1.3
em2884 #0: V4L2 video device registered as video0
em2884 #0: analog set to isoc mode.
em2884 #0: dvb set to isoc mode.
        Use it with care.
drxk: Could not load firmware file dvb-demod-drxk-pctv.fw.
drxk: Copy dvb-demod-drxk-pctv.fw to your hotplug directory!
TDA18271HD/C2 detected @ 4-0060
DVB: registering new adapter (em2884 #0)
usb 1-2: DVB: registering adapter 1 frontend 0 (DRXK DVB-C DVB-T)...
em2884 #0: Successfully loaded em28xx-dvb
[AUD]: AUDIO_STOP 1
FE tune c
angelofsky1980
Into your system there is no firmware file for your stick...
Obtain it and place into /lib/firmware folder and reboot your box ....
Or you can install the attached package:
1. upload into /tmp folder for your box
2. use the Manual install BH Package into the image (green->yellow buttons) to install it.
3. remember to reboot yoru box!
  • firmware_pctv_520e_bh.tgz
sharky
This time it seems to be ok.
thank you
By cons I can not find how to change the tuner
This is certainly a lack of knowledge on my part
        Use it with care.
FE tune c
FE tune c
        Use it with care.
FE tune c
FE tune c
FE tune c
FE tune c
FE tune c
is what I need to be able to add an extension to manage it?
angelofsky1980
thank you
        Use it with care.
FE tune c
FE tune c
        Use it with care.
FE tune c
FE tune c
FE tune c
FE tune c
FE tune c
Could you please post the output of the following command?
cat /proc/bus/nim_sockets
sharky
thanks for your support
NIM Socket 0:
        Type: DVB-C
        Name: Vuplus DVB-C NIM
        Mode 0: DVB-C
        Mode 1: DVB-T
        Frontend_Device: 0
eminem093
Hi
Any news with this tuner type
vu+duo2
dmesg show ok
Black hole v 2.17
NIM Socket 0:
Type: DVB-S2
Name: Vuplus DVB-S NIM(AVL6222)
Frontend_Device: 0
I2C_Device: 2
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
I2C_Device: 2
NIM Socket 2:
Type: DVB-C
ontend
Frontend_Device: 2root@vuduo2:~#
no 3 tuner in choose tuner meniu
Thanks
angelofsky1980
Hi
vu+duo2
dmesg show ok
Black hole v 2.17
NIM Socket 0:
Type: DVB-S2
Frontend_Device: 0
I2C_Device: 2
NIM Socket 1:
Type: DVB-S2
Frontend_Device: 1
I2C_Device: 2
NIM Socket 2:
Type: DVB-C
ontend
Thanks
It's strange.
If into /proc/bus/nim_sockets file the tuner is present, Enigma2 should use it.
Have you made online update?
I need the debugfile to understand what happen in your box: http://www.vuplus-community.net/boa...images-debug-script-per-le-immagini-bh.21512/
