Dear Sirs,
As representatives of a number of Vu+ Duo users gathered at dvhk.pl sat forum in Poland, we would like to draw your attention to escalating problem of CAM modules failing to operate in your tuner. The ones especially important to Polish viewers are: Polsat Cyfrowy and TNK HD. Buying equipment of 400 euro worth we did expect CI functionality to be fully operational which unfortunatelly is not a case. We would greatly appreciate if you colud present your position on this and prsent anticipated fix time.
Looking for prompt reply.
Kind regards
Vu+ Duo users Poland
Kind regards
