VLC Streamer by HellX
a911
The BH Lover
-- VLC Streamer by HellX ----
Tool to easily start streaming/transcoding from your
Compatible with E1 and E2 Images.
PS!
VLC Player must be installed on your PC.
Changelog:
v1.2:
- Added possibility to remove "PCRPID" from video streaming URL (E1) (Advanced feature, normally not needed)
- Added possibility to send "Kill Streaming process" on DB when Channel change. (E1) (Advanced feature, normally not needed)
- Added "Caching" when streaming.. Set value in millisecond in Transcoding tab. (Default 1200 ms)
* How to Remove PCRPID and set "Kill Streaming Process":
1) You can add to keys i registry to activate the features..
Goto "HKEY_CURRENT_USER \ Software \ VB and VBA Program Settings \ VLC Streamer \ Settings", and add to new "String value".
"NoPCRPID" and "KillStream", set "Value data" to "1" for activating feature. Restart "VLC Streamer"
2) You can activate the features via command line arguments...
Start "VLC Streamer" via command window (cmd). Add argument "-nopcrpid" for NoPCRPID in streaming URL.
Add argument "-killstream" to send "Kill streaming process" on DB when channel change.
Example: In DOS write "VLC Streamer.exe" -nopcrpid -killstream
Thanx t0 HellX for this tool!
  • Vlc_Streamer_v1.2.rar
  • vlc-2.0.0-win32.rar
