Neues VTi "Vu+solo Team Image" - v. 5.0.0 - 11.12.2012 OE 1.6 CHANGELOG * dvbapp2: 11.12.2012 * drivers: 25.10.2012 (09.11.2012 Solo²) * plugins: 11.12.2012 --> changes from Vu+ : http://code.vuplus.com CHANGELOG VTi * added to image - AutoShutDown plugin * added to download feed - EMC 3.6.6beta (2012-12-05) * updated packages - openvpn (ver. 2.2.2) - switch WLAN drivers from rt3070 to rt5572 - update WLAN drivers r8192cu (3.4.4.4749-20120730) * kernel - added kernel modules for netfilter dscp target and mangle modules * dvbapp2 - show icons in timer list - enable REC button for managing all timers (not only instant records) - press REC button long for showing a list of all running timers - enable REC button functions at playback (MoviePlayer e.g. EMC) - add option for deleting finished timers automatically - add option to priories feed updates (opkg option --force-overwrite) - language menu shows only installed languages - VTiZerO and VTi BackupSuite integrated into startup wizard - package split for dvbapp2 package to reduce required update space - bugfix "silent rec mode" (timer action "DeepStandby" works again" - update cs translation (THX @Roxy) * VTiPanel - restructure of menu - VTiZerO: option to recover removed packages - image backup: backup is not saved to /media/hdd anymore by default (only to configured backup path) - show hdd temperature independent of device /dev/sdX
