Vu + drivers for asiasat 5
/etc/enigma2/lamedb file (backup your file, this contains ~ 20 satellites channels)
Thanks i've given it a go, but still the channels do not work on my Ultimo :(
Do these channels still work for you right now ? Just wondering if they were fta when you scanned them in and thats why you were lucky enough to see them.
Ahh problem solved, the wrong drivers were uploaded earlier so the Ultimo couldn't scan the channel still.
Now with the correct drivers it is scanning them :)
Hi Everyone.. looks like VU+ has done a fix for this issue. Follow the below steps
1) go to plugins and then addons AND THEN ONLY choose fpga upgrade,
2) then download this file using this link - http://archive.vuplus.com/download/drivers/lowbr/UNO_TS_PRO.dat
then u have to send this file to tmp folder thru dcc and close dcc. and then in the receiver go to pluigns file browser and go to tmp folder and install the .dat file.
3) when you install it it will take about 5 minutes.
4) then download and using winrar unzip the file - http://archive.vuplus.com/download/...dvb-modules-vuuno-3.1.1-4.4.3-20120809.tar.gz
you will find 4 files and then send the 4 files to lib/modules/3.1.1/extra/ and replace the old files
the 4 files are brcmfb.ko, dvb-bcm7413.ko, fpga_directc.ko, procmk.ko
5) restart receiver and then search for channels using frequencies and then
vu uno should lock the channels HD.
how to do this on my vu+ duo2 and on my vu+ solo2?
thanks
I think this is a version of dreamset and it's allowed to change PMT pid but which version? Because I can't find it :(
