Hello
I have a problem with the tuner, mentioned voltage capacitors are good, the problem with the start of the tuner on the console after the rs-232 displays:
BCM73350010
012
Shmoo Version = 1.9
MEMC-00000000
and so stops
using Broadcom studio received any utf like. obfuscating the flash and wgrywałem tuner again but still retains the same way.
I question whether it can be a problem even tensions in the systems:
U806
U807
??? could someone to enter the correct voltages on these systems?
capacitors on the board mentioned. I checked into account errors and solder connections. I wonder voltage at 0.9V U806 should be like? or a problem with RAM ??
Regards
BCM73350010
012
Shmoo Version = 1.9
MEMC-00000000
and so stops
U806
U807
Regards
