snellie1972
Can somebody help me my vu-duo only shows a red light and i cannot flash the box not by USB and not with the VU-Util tool neither can i use putty
Thanks in advance
Thanks in advance
We need more information, maybe I or some in the forum might be able to help you if we have more information on what has fully happened to your Vu+Duo box to make it only show a red light.Can somebody help me my vu-duo only shows a red light and i cannot flash the box not by USB and not with the VU-Util tool neither can i use putty
Thanks in advance
To upgrade the boot loader, you can refer to this thread: Vu+ DUO Boot Loader UpdgradeWell i tried to flash to flash the box trough USB with the bh 1.6.6 version after that the screen stays black then i saw that ik had to put in a new boot loader after that the box is dead ( sorry for my english )
Thanks in advance
i have tried to upgrade the bootloader but on the vu-duo there is still a red light nothing more
For the moment , I would recommend to go for BH 1.6.5 (USB),,,and see what would happen!
Remember to remove all USB and internet connection from the back!
My problem is that it will not flash trough USB or trough vu-util so that would,nt work
With vu-util you can flash the box with serial and utpWhat U mean by Vu-util.....?
Yes i have used a new formatted usb but i think the bootloader is corrupt
Then try with Vuplus official image (older than ver 6)....!
Can u go in the STB with DCC_E2?
I have a serial NULL modem so i hookedup the vu duo made a hyperterminal connection on 115200 baudrate on com1 then i turned on the vu -duo but nothing happens
