My box seems to be dead as all it says in front panel is vu*solo2 nothing else I've tried reflashing still does exactly the same can any body point me in right direction
i have also here vu+ultim cant even flash image , i tried evrythink even null modem cable no go .
but the strange this is de reviever boots well i can see the channles on the screen but u cant controle it .
i dont know what should i do guys help me ..
hi I had red light issue in my vu duo.I replaced c807 and worked 2years but again red light issue.in my psu I've changed 2 1500mf and red light gone but when I tune a canal front panel not work,remote not answer,jog not work but I connect a wireless keyboard I can change canal and ...
please help?what's problem when tune canal and get a picture then don't work front panel?
Hi guys I got a Vu+ duo box and it’s showing a red light I tried everything I could think off with usb stick formatting low level and with rs-232 cable on my pc and nothing seems to work with me. Is it the capacitors that I need to replace ? And where do I buy one from if I need to change capacitors ?
I have the same problem with my VU+ UNO - red light on start - been like that for 2 years and I have finally decided to fix it.
None of the capacitors on the VU+ UNO board are marked C807 and it looks very different from the DUO in the pics here.
None of the capacitors on the board look damaged - none bulging - none leaking.
Which capacitor is the VU+ UNO equivalent of the DUO's C807?
