VU+ Duo no channels
Try setting B up to Single, Astra 2, 28.2E, and scanning in channels on B, set A to not configured. Just to check that it's not a problem with Tuner A.
Do you get voltage reading from lnb connections on box when on? If not it sounds like your only option is to send box in for repair as it sounds like voltage or hardware problem. hth
done that but ends up the same. just noticed my SNR is at 0% flickers now and then. my AGC is at 99% BER is at 0 another box works fine on the cables.
