Vu+ Duo vs DM500HD
Is it true that DM500HD CPU is dual core and Duo is not? Which one has the fastest CPU?
Duo is a dual-core CPU and the dm500hd too.
The two boxes uses 2 different CPUs.
CpuInfo of my Duo box:
root@bm750:~# cat /proc/cpuinfo
system type             : BCM97xxx Settop Platform
build target            : bm750
processor               : 0
cpu model               : Brcm4380 V4.4  FPU V0.1
cpu MHz                 : 402.43
BogoMIPS                : 402.43    ( udelay_val : 201216  HZ = 1000 )
wait instruction        : yes
microsecond timers      : yes
tlb_entries             : 32
extra interrupt vector  : yes
hardware watchpoint     : no
ASEs implemented        : mips16
VCED exceptions         : not available
VCEI exceptions         : not available
RAC setting             : I/D-RAC enabled
unaligned access        : 1
rdhwr/brdhwr traps      : 0 / 0
process migrations      : 334
processor               : 1
cpu MHz                 : 404.48
BogoMIPS                : 404.48    ( udelay_val : 202240  HZ = 1000 )
tlb_entries             : 32
I guess that Vu+Duo have at least the same (or better) quality hardware than DM500HD (the Vu+Duo software is the best, thanks to BH team, that's for sure :thumbup:).
Vu+ (all boxes) have at least 2 USB ports avaable, dm500hd needs an hardware modification (who invalidate warranty!!) to use this kind of connection... :)
If you want compare it:
DM500HD
root@dm500hd:~# cat /proc/cpuinfo
build target            : dm500hd
processor               : 0
cpu MHz                 : 402.43
tlb_entries             : 32
RAC setting             : Unknown
unaligned access        : 2032247
process migrations      : 435
processor               : 1
cpu MHz                 : 404.48
tlb_entries             : 32
VU+DUO
processor               : 0
cpu MHz                 : 402.43
tlb_entries             : 32
unaligned access        : 2186344
process migrations      : 603
processor               : 1
cpu MHz                 : 404.48
tlb_entries             : 32
B
DM500HD
processor               : 0
cpu MHz                 : 402.43
tlb_entries             : 32
processor               : 1
cpu MHz                 : 404.48
tlb_entries             : 32
VU+DUO
processor               : 0
cpu MHz                 : 402.43
tlb_entries             : 32
processor               : 1
cpu MHz                 : 404.48
tlb_entries             : 32
è montano lo stesso identico processore.
This is an international section so you have to speak english.
P.S. Yes it is the same CPU!
si praticamente la stessa identica CPU!
Thanks for your report. It's very useful.
Reading on the web, the Duo and dm500hd has reported with 2 different CPUs. I have learned another thing :)
For me, these two risivers simply not comparable because they are completely two different classes, the basic unit dm500hd and VU + duo is advanced product, the top!
