Vu+Duo won't restart-start
I bought my stb from a trusted suplier here in the Netherlands. i dont even consider it's a clone (though the box is mabe 3 years old now). All images i uploaded of BH worked perfectly on the box. Never use a back up when i upgrade. Start everything fresh and download the latest settings from the BH download menu.
I will try new USB and channel scan like u advise, will keep u updated.
If it's stuck at boot try removing the network cable and reboot. If it boots put a manual IP in the network settings and plugin the network cable. Some times an image doesn't like my dhcp. I use static IP addresses but always remove the network cable for a new image first load.
