Vu+ Duo2 Dead with white light on
hi to all
the same problem with the famous white light
after installing the latest Image BH 2.1.1
he does not want to start it stops on the white light only no boot detect,
the fan does not work,
it does not detect any USB device so that I can flash,
(I tried 4 different types of USB .. with different version of BH .. and also different Original Version .. nothing is happening with duo2 .. just the white light present)
:eek: :help:
Same probleme withe Bh 2.1.7 :wallbash::wallbash::wallbash:
Help.....
i think , it has capacitor ' s problem .
because in all other receivers ( in red light and ... problem ) if change specially capacitors of power , device booting up again .
start from power ' capacitors .
test and change all of them . one by one .
and every of the capasitors changed ;
test it .
if repairad please tell to us .
saeed, or anyone else that can help.
Did you get the list of capacitors required from that links author?
I would love to get a copy please.
hi
i am waiting for list of capacitors . if they send for me , i put it here .
but you can open the box and write the name of capacitors of power and first :
change the power board capacitors with the same high quality japannis capacitors .
thanks.
