amila perera
Hi there,
I did inquire from avilink technical support about higher symbol rate issue on vu + duo2 dual tuner. They told me to add following patch. But I have no experience on how to do it. Could you please look into it. The message which they sent me is as follows.
From your message, the AVL6222 can lock signal,, but get any services for SR =45msps?
For crystal and TS config, please following:
AVL_DVBSx_SA_0,
Ref_clock_Enhance_10M,
AVL_DVBSx_MPM_Serial,
AVL_DVBSx_MPCP_Rising,
AVL_DVBSx_MPF_TS, //not use AVL_DVBSx_MPF_TSP
AVL_DVBSx_MPSP_DATA7,
And try update attached AVL6222 SDk and FW ,re-test, thanks;
AVL_DVBSx_SA_0,
