Hi a911
I have tried to mount this drive, however the recording path does not show the /hdd/movie option. It only shows the f lash option as in usb/media/ option which it seems to be the default path which I cannot adjust.
I think there is something not quite right because I keep getting a green screen with data information closedown and then it reboots the receiver from the B/H shutdown.
I think what is happening is above my knowledge, maybe I need a basic update flash of the receiver, however i have tried to flash 2 different new images and neither will update, I have used the usb method using VIX version 2.4.96 and I have tried BH 1.7.4 and 1.7.5 universes. I have used how to flash info from this forum and followed it to the letter, but alas it has not worked. keeps booting up in old BH version.
Can you guide me further, or do I need to get professional help to get this hard drive to work?
I once again thank you for your expertise from my first post and am willing to try any suggestions, even if it means taking out the hard drive and starting from scratch again.
Kind regards KJT
