angelofsky1980
BlackHole Driver Specialist
v5.5 Release notes:
Open Embedded -
- Please take a look at git log
Driver update
20101125
- Fix HD playback problem(solo)
20101129
- Disable HDMI hotplug at standby mode -> rollback
20101203
- Support audio lipsync control
- Memory usage optimization(solo)
- Fix high cpu usage in ts playback
20101221
- Fix audio lipsync control(minus value)
- remove v4l-vuplus.patch in the v4l-dvb-modules
- Clean and speed up the demux driver(shoudl be used with new v4l-dvb-modules driver)
- Speed up trick mode in ts playback
- Fix CI module recognition problem at bootup.
- Support high CI bitrate
- Support rf_switch proc interface
Duo:
USB
NFI
Solo:
USB
NFI
Open Embedded -
Driver update
20101125
20101129
20101203
20101221
Duo:
USB
NFI
Solo:
USB
NFI
