Vu+ Player now available!
Thanks friend and configure the program DreamStreamoid version 1.25 so we can watch our channel VU +
DreamStreamoid pro is a android client for enigma2 receivers (e.g. Dreambox, VU+, IPBox, QBox).
The focus is on the streaming of TV, radio and recordings.
You can easily stream channels and recordings, switch channels, browse the EPG and choose bitrates and scalings via mobile phone.
You can stream content using Daroon player, VPlayer or over a VLC-Server!
Pro-Features:
* Multi EPG
* Automatic player switching
* Booting and shutting down the VLC computer
* Support for audio tracks
* separate radio settings
* improved radio player
* Notification function
* more features will follow...
PLEASE TEST THE FREE VERSION FIRST!
Recent changes:
Android 2.2 - 3.0
-faster reload of the multi epg
Android 3.1+
-new tablet version
-EPG config
I am also using another app (Dreamdroid) to stream and control my Vu from my phone. Bu t it would be great to see an official vu app for my android!!!
It's not clear if this works with iPhone 3GS. Does it?
You are right, it's not clear.
You can do a simply test with your iPhone, you can try to buy the app.
If the app it's not compatible with your iPhone, it will appear a box message with the notice.
You have not to pay to do this test ;)
I hope you're right :)
I guess you need iPhone 4, that's what the text says. They probably lumped the 3GS in with the regular 3G.
I just got this reply to my question from Bessem Rebai on the Vu+ Facebook page:
"Requirements: Compatible with iPhone 3GS, iPhone 4, iPhone 4S, iPod touch (3rd generation), iPod touch (4th generation) and iPad. Requires iOS 4.0 or later."
I'll definitely be getting this app, so I'll let y'all know what it's like on 3GS once I've tried it out.
Well... I have an iPhone 3GS (iOS 5.0.1)
I bought this App a few minutes ago...
It works good! :D
Good zapping timing... Good picture quality.
So please add official support of iPhone 3GS in next release of this App.
3GS in not like 3G. It can make it... ;)
And an other suggestion please.
A lot of as have a USB Tuner for viewing DVB-T channels as well as DVB-S channels.
Personally I have a Technisat AirStar TeleStick 2 (with "dib0700" chipset)
http://www.technisat.com/en_XX/AirStar-TeleStick-2/352-1292946849659-15145/
that works great with my VU+ Uno (VIX v2.3 Build 204).
I think it's a good idea if we can see the picture of USB Tuner's channels too.
I hear the voice but I have no picture when I choose them.
Off course this is only a suggestion. I don't know if this is something that you can do or you have hardware limits to do this.
Overall. Thank you for this great Application... :)
What phone, what IOS, did you make configuration (IP, login data)..
my iPhone is 4G with IOS 5.1.1
and i configure it like (Manual - i put my Vu+ Uno IP Address - Zap mode : Mirror - Render : Middle - web-interface Port : 80 - username : root - Password : nothing - cache : 2500)
so if i have to something else please help me
i use BH 1.7.4
i use BH 1.7.4
Your setup seems to be ok and it should work.
However, try to setup the "Single Tuner" zap mode.
