Vu+solo and usb dvb-t2?
mako74
What dvb-t2 usb tuner can work on the vu+solo?Whether it is possible to use the terrestrial DVB-T2 channels?
gangoja
Can anyone suggest a cheap usb dvb-t2 tuner working on vu+solo, i've heared there are cheap chinese t2 tuners working fine on linux, thanks.
angelofsky1980
BlackHole Driver Specialist
Actually there is no CHEAP DVB-T2 USB tuner.
The PCTV 290e is supported. Other... (if exists): depends.
gangoja
Someone in another forum wrote that he is using successfully a chinese dvb-t2 tuner with AF9015 chip, it is silver colored with a blue led, i did pm him for asking where did he buy it and they were out of stock already there, probably there are cheap dvb-t2 usb tuners around.
angelofsky1980
I think DVB-T2 with AF9015 chipset is not yet implemented by driver author, so it's useless to try to use that kind of devices.
gangoja
Probably you are right, in fact searching by google there is only the PCTV 290e found as a dvb-t2 usb , there is another one on the chinese site ******* that i found but who can trust them, maybe I have to wait a little for a cheaper t2 tuner :D
