vu+solo green led heelp
tsouli
i have a solo blocked in a green led , i have flashed him by vu+util and nfi original image,but no results :s ,after,he was flashed by usb original image,no results, plz help
angelofsky1980
BlackHole Driver Specialist
What image do you have used?
Have you tried with an old image? (OE 1.6)
Matrix10
noo black screen
1.Have you checked HDMI Cable
2.Have you checked on with the other HDMI port on the TV.
3.Have you checked with a Scart cable.
I think that's the HDMI problem .
Try to turn on and turn off the TV when the box is already on.
roozbehk
check your usb flash and make sure it is formatted by fat32 file system.if it is not, then format it again.and make sure yo have vuplus folder on the flash root and inside it solo folder.
and for the question. did led start to blinking after 4 or 5 minutes?
mkm
sal vu + solo have a picture stuck on bright green Ledu stay than at the remote no longer responds back button is given restarteaza sees nothing on TV and another image with stiku not receive sma help you with something original aparatu is not clone
angelofsky1980
If it's original, reinstall the image.
mkm
Receiver is 100% original original image where do I get that I have not done before the rec Bacup
Matrix10
vu util
Fail to upgrade you machine[step:4,err-code-21
What image did you have in the box before.
I think you had an old image and you should first make an bootloader update
Of course, provided that you have original box.
With USB stick Bootloader update and than with USB stick Image update.
You have to try , with different USB sticks.
If this does not help then contact the Seller.
mkm
ok I'm looking for a way to resucito it even with jtag not want to contact the Seller.
mkm
helo after I installed this picture
vuplus-image-vusolo-20140714170525.nfi
I recommend that you load the files in solo vu +
I Puso cable image RSR that was blocked vu
