I am trying to Buy my first enigma 2 receiver I came from cheaper boxes.(like openboxs)
According to my Budget I am seeing VU+solo and Vu+duo..
I know that VU+duo has little bit more memory and features that Vu+solo but appears that both are still under memory than others VU+ receivers on the market..
I really do not need twin tuner.. with one tuner is enough to me..I do not need to put HD into the receiver, via Usb to HD is enough
My question is : Is really worth of value to spend a little bit more "dls/euros" to buy VU+duo than VU+solo?
what are the advantages of the VU+duo compared with VU+solo?
What I am looking for: Capacity ( my receiver can run smothly the plugins), still under on support, iptv,youtube, media player, good scan,obvious Quality picture, and much more..
Vu+solo has more limitations compared to VU+duo? or both are the same thing except for the dual tunner
thanks in advance
thanks in advance
