VU+Solo Upgrade from 1.7.9 to 2.0.8.1.
MrItizai
Hello everyone!
As the topic says, i have a VU+Solo with version 1.7.9 running pretty well, but i think it's about time to upgrade it to the last version, but i have some questions about it.
The image of version 1.7.9 has more than 47MB, so there's no need to update the bootloader, so my question is, can i upgrade it to the last image version, 2.0.8.1, using the normal usb method, without the need of some extra procedure.
I ask this because from version 1.7.9 to 2.0.8.1 theres a major version change (1->2) and normally it implies some extra effort to make it work.
Thank you all,
Best regards.
Thank you for your reply friend Mito.
Tonight i'm going to upgrade it then according to your suggestion.
Best regards.
