vu+solo2 avermedia volar green hd
netlom
good morning,
I have the vu + solo2 and try using a avermedia hd green fly, which does not recognize me.
I attached the instruction cat / proc / bus / usb / devices
as I'm missing tdt plugin, you can help me.
Thanks and sorry for my english
  • cat proc bus usb devices.txt
Shiro
BH-C
External link are not admitted.
But this time we can make exception because these are links to linux and kernel tech boards
netlom
if only a part of dmesg
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
Custom Black Hole build
usbcore: registered new interface driver dvb_usb_it913x
it913x: Chip Version=01 Chip Type=9135
it913x: Remote propriety (raw) mode
it913x: Dual mode=0 Tuner Type=38
usb 2-1: dvb_usb_v2: found a 'Avermedia A835B(3835)' in cold state
usb 2-1: dvb_usb_v2: Did not find the firmware file 'dvb-usb-it9135-01.fw'. Please see linux/Documentation/dvb/ for more details on firmware-problems. Status -2
usb 2-1: dvb_usb_v2: 'Avermedia A835B(3835)' error while loading driver (-2)
usb 2-1: dvb_usb_v2: 'Avermedia A835B(3835)' successfully deinitialized and disconnected
__clk_enable: network [1]
__clk_enable: enet [1]
bcm40nm_pm_genet_enable 00
ADDRCONF(NETDEV_UP): eth0: link is not ready
eth0: Link up, 100 Mbps Full Duplex
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
svc: failed to register lockdv1 RPC service (errno 124).
[LCD]: unknown cmd 0x1015
[CI]: CI interface initialised
eth0: no IPv6 routers present
netlom
good
already recognized, I downloaded a file it9135 internet, I've changed the name to it9135-01 and finally recognizes it and I can see the channels.
Many of the channels are pixelated, can be due to the downloaded file? or should we refine the driver.?
thanks
angelofsky1980
BlackHole Driver Specialist
good
thanks
I will add the firmware file to the image in the next days ....
angelofsky1980
I've found the firmware files needed and will be included in the next BH ... for your use, I will post it an IPK when I prepare it this evening.
CoPeRniX
Sorry,
I'm Volar green with chipset A835B and BH 2.0.2 not reconigset tuner TDT.
where I can get the driver ipk??
Thanks.
dpeddi
I confirm that black hole should support this pen from about 3 month. Please follows angelofsky instrunction.
