Vu+ Solo2 + signal lock
tuskerkeg
Hello
I recently purchased a Vu+ Solo2 to replacing my aging DM500.
My excitement is slowly turning to a nightmare as I am not able to lock to any satellite signal.
The same coax/cable connected to DM500 is able to lock with eb/no of over 10db
I have tried both tuners and results are the same.
I tried different versions of vix software to no avail, what could be wrong
hw/sw details
Brand:Vuplus
Model:solo2
Chipset:7356
Frontprocessor Version:0
Total Memory:571748 kB
Free Memory:500316 kB
Box Uptime:0:03
Software
Kernel version:3.3.6
Firmware version:Experimental 2012-12-21
Gui version:Dec 21 2012-vuplus_experimental
Tuners
Tuner A:BCM7356 DVB-S2 NIM (internal) (DVB-S2)
Tuner B:BCM7356 DVB-S2 NIM (internal) (DVB-S2)
Hard disk model: ATA(WDC WD5000BPKT-7)
Capacity:500.107 GB
Free:250.140 GB
Network interface: eth0
DHCP:True
Ip address:192.168.1.102
Subnet mask:255.255.255.0
Gateway:192.168.1.1
Mac address:00:1d:ec:04:92:9f
You have not specified the most important
What kind of satellite installation
do you have
and how did you configure in solo2
It's better to use a ready made sattelite settings for Enigma2, like Vhannibal. No need to lock every sattelite manualy.
do you have
My bad,
config mode = simple
mods = single
satellite = eutalsat ( 36.0E)
send Diseqc = 0
With the above , a manual scan yields 0 services
No lock either with satfinder
where is your dish pointing at? I doubt it's eutelsat 36 deg
what channels would you like to watch? or: what channels can you watch on your DM?
May be the copper wire of your antenna cable into the "F" connector connected to your tuner is a bit too short.
Try to make it a bit longer.
