Vu+ Solo2 Streaming Problems
Download the file with the drivers you want. Extract the 4 files and send it to /lib/modules/3.3.8-2.0/extra. It will ask you to overwhrite files, select yes and reboot.
I installed ipk file through ts panel is it the same thing?
Will i be able now to stream on my samsung tv and which is the best streaming application for samsung tvs?
Can i stream 4.2.2 feeds from my solo2 to samsung tv?
Isn't that soft above kinda unsearchable in the searchfunction ??
without space or hyphen
http://www.vuplus-community.net/board/threads/ts-panal-on-solo2-help.13847/#post-104214
NO TS PANEL SUPPORT HERE!
About user question: NO you cannot stream 4:2:2 feeds directly from Vu+ (any model) to TV (any model).
You need a PC and VLC to re-stream the channel.
Hi, i've BH2.1.1 on Vu+solo2, when I use transcode on a recorded program i can't change the language and it broadcasts the wrong language, i configure the language on the audio and i have no problem when i watch a multilanguage channel, any idea??
Thanks in advance!!
Hi, I have the same problem.
I am watching TV only with PC on VLC player in port 8001 without "transcoding".
On LAN connection video quality is very good.
Outside, quality is very bad. Resolution is only 416x224.
I think, that is something wrong with my settings.
Previously was fine, but I have made some changes, and dont remember what... :)
It is possible to reset OpenWebIf to "default"? maybe it is possible to change bitrate or something?
Internet speed between Box and PC is 100mbps...
It is possible to disable the "transcoding" function? On menu I can change only the port number, framerate and etc., but how to turn it off
completely? :)
Thanks
Witam Problem mam, z V + SOLO 2 mianowicie po zainstalowaniu nd wyswietlaczu lcd picons nie mam Jaki kanał w danej chwili mi LECI TYLKO żart mala ikona hd Menu Jak wciskam na WSZYSTKIE Komendy ukazuja sie NA wyswietlaczu Nie Kumam o co chodzi po wyłączeniu Nie ma Też Godziny?
