thefurmanuk
Hi,
I have had my solo2 for about 3 weeks after replacing a faulty duo which was 18 months old. I tried to start it yesterday and it came up with a menu offering only shutdown, restart, restart enigma or standby - everything I pressed did nothing except restart the box. I switched off from the back and switched on and it was stuck on Starting.... for ages. I did this again and same thing, the third time it started normally.
I am using BH 2.0.6.
Should I return to the seller and get a replacement or avoid VU? I don't want to replace if the solo2 is prone to these errors. I never had this with the duo until it died with red light problem.
Thanks
Thanks
