Vu+ Solo4K tested for you!
Hi black hole team
i have problem in the channels with audio ac3
the channels dosen't have audio
have solution for that?
my stb is solo 4k and ultimo 4k with black hole 3.03E
thanks a lot
Hi all,
can someone provide info about compatibility of using Solo 4K with MSW and diseq switch, because of FBC tuner.
My config:
2 quattro LNB's => MSW,
4 single LNB's => diseq SAR 411,
MSW => SUR 211 input 1
SAR 211 => SUR 211 input 2
SUR 211 => Zero 4K
With this config. everything is working as it should on Zero 4K, will Solo 4K be capable to have same configuration.
I read somewhere that FBC tuner in Solo 4K cannot manipulate with kind of config?
Beside this, if you compare Solo 4K and Zero 4K what would you choose?
Thanks!
