Vu+ SOLOSE not working with USB TDT HD Mygica T119
Could you try replace attached files?
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9035.ko
/lib/modules/3.13.5/kernel/drivers/media/usb/dvb-usb-v2/dvb-usb-af9015.ko
/lib/modules/3.13.5/kernel/drivers/media/tuners/tuner_it913x.ko
/lib/modules/3.13.5/kernel/drivers/media/dvb-frontends/af9033.ko
Bye
YOU DON'T KNOW WHAT KIND OF DRIVERS ARE USED INTO BH IMAGES, SO PLAY AROUND KERNEL OBJECTS, REPLACING THEM OR MAKE OTHER OPERATIONS, IS NOT RECOMENDED AND NOT SUPPORTED.
Hello
sorry but that I interfere
the Mygica T119 is a clone siano
as all
usb dvb-t siano clone
hauppage.com
DVB-T Stick hauppage WinTV mini Stick
Crypto.gr
DVB-T Stick Crypto ReDi pc 100
mygica.com
DVB-T Stick MyGica T119
geniatech.com
DVB-T Stick Geniatech S119
linux Driver
S936/SF118/S118/S119/T119 Driver for Linux
geniatech / dowload >
http://geniatech.com/file.asp?id=66
There are 2 versions, the old T119 uses the drivers sianodvb, and the new version of February 2014 uses the driver IT913x
I have the 2 models.
Bye
Hello, I have the same problem. My vu+ solose with firmware xbmc beta 02 can't recognize my usb mygica t119 (which works fine in windows with driver 9135). Is this problem going to be fixed for the next bh image for solose?
Xtrasto, do you think that your method can also work fine with the BH solose xbmc beta 02? Did it work for someone else? Just to be sure of the steps, you mean that i have to install the bh firmware using a usb pendrive while having the t119 inserted in the other usb port. Is that correct? Can it be dangerous for the decoder, so it could become a brick?
Thank you very much
