Vu+ ULTIMO Firmware Upgrade
Hello
I got problem with my ultimo, I connect tuner A works fine, when I connect tuner B, screen will be as below, I thought there is problem with tuner itself, removed tuner A and B and checked individually each tuner singe, both tuner works fine alone, problem pop up if only i connect B tuner.
FYI, I don't have problem with my Duo, i used latest official software release, still problem remains. do you think that i need to upgrade FPGA?
screenshot-jpg.12985
Thank you
Hello
Thank you
If you haven't updated it before, do it now.
Thanks for your quick reply,
I do not remember, but i shall do it and update you result here, i got below drivers and FPGA update:-
h**p://archive.vuplus.com/download/fpga/vuultimo/4.5/
h**p://archive.vuplus.com/download/drivers/
by the way, said drivers suppose not to be included in new images? as mentioned before, I used latest official release and last two BH release!
Regards,
I suggest to use dedicated plugin to upgrade FPGA instead to select manual files.
Thank you Boss
after update of FPGA via dedicated plugin in BH, tuner B working fine 100%
Remained Q? Why latest images even original been released while still We need to update FPGA! Why FPGA not included with new images.
Thank you
Thank you Boss
Thank you
FPGA it's a dedicated hardware chip on the mainboard of Ultimo box and needs a dedicated plugin (operations) to be updated.
When you update it, you don't need anymore to do the same operations when you reflash and/or change image.
When Vu+ releases a new upgrade all users will be noticed with this Board and the official Vu+ web site too.
Thank you for your close follow up,
You logic is true and such upgarde need to be done once, just remembered last year done some for UNO
Hope we dont have said issue with duo2 as i ordered one :)
It was a good experience for me
Cheers
Sent from my iPhone5 using Tapatalk
Cheers
Actually there is no FPGA upgrade for Duo2 but only VFD controller who increase RC sensitivy :)
The VFD controller upgrade is similar than FPGA upgrade and it's done via a dedicated plugin
Thank you very much for useful himt, i will keep in mind to do same as soon as i get my duo2 :)
