Then your VU+ Ultimo can't be connected to your network, i.e. router, or the image hasn't been set up that far.
You will have to check the vuplus website, or try contacting vuplus support.
Report your problems and ask if it's a known hardware fault, or software.
With the receiver being so old you might have to try and find a local electronics repair shop, and see how much they will charge to check the power supply, and circuit board, for obvious problems.
