Will the lcdpicons of the vfd display be supported again on the next 3.0.0 image or has support stoppped for them ?
they haven't worked on the vdf display right for the last 2 images ported for using the normal picons wich don't look right on the vfd display wich is reported by others but no solution sofare i hope it's fixed in the next releaseWhy not? All should be ported normally.
no we would have a picon folder for that and lcd picon folder for the vdf display but for some reason the images uses the normal picons on the display after loading the skin.xml folder from the black hole server wich we need for the display even in that it says that it would use the lcd.picon folder but it still displays the normal picons i have tested this by removing picons out off the normal picon folder and then there is no display on that channel on the vdf
