Hi All,
I have had a little mis-fortune today with my Ultimo, after setting up a new hard drive the Chip Regulator located near the power supply has burnt and is now not working would anyone know where i could get a replacement.
The Regulotar that is burnt is labelled U805 which is the same size as the U806 but from what i can gather they are smaller than what are used on the Vu Duo so the regulators from the duo will not work.
Thank you
Thank you
