VU Ultimo Remote Key Help
gobi2000
I'm hawe problem of vu ultimo remote, posible swich the remote Abcd... from number 1234...
Web keyboard is what gives a bit of trouble switching from letters to numbers fail
Thaks from answer.
gobi2000
Please give me an answer if you work the number ke*ys on the keyboard, I have succeeded in any way to make them functional ... Thanks in advance.
Mombik
Hi,
Have the same problem with the remote of my new vu+ ultimo.
On the keyboard I can't type the figures 1 to 9.
Do you remember how you fixed it?
Thanks.
Best regards.
Mito
Hi,
Thanks.
Best regards.
It seems to be an issue still not solved.
