miamio82
Hi guys,
I'm trying to use as102 key (sky digital key green led) on my vu uno bh 1.6.6.
Blue -> blue -> tuner usb and I installed pctv 74e drivers.
It was installed successfully and enabled it successfully but in configuration-> search chan -> config tuner, i've "dummy tuner" not supported.
Here is part of my dmesg...
as10x_usb: device has been detected
DVB: registering new adapter (SKY Italia Digital Key)
DVB: registering adapter 1 frontend 5 (SKY Italia Digital Key)...
as10x_usb: fimrware: as102_data1_st.hex loaded with success
as10x_usb: fimrware: as102_data2_st.hex loaded with success
usbcore: registered new driver Abilis Systems as10x usb driver
__pa invalid address 0xa1fb8000
Break instruction in kernel code[#1]:
Cpu 1
$ 0 : 00000000 10008b00 00000023 8032bb54
$ 4 : 8032bb50 10008b00 00400000 10008b01
$ 8 : 00000000 0000000a 00002824 80380000
$12 : 8038a8f2 0000004c 00000008 00000000
$16 : 827d2e08 a1fb8000 ef05bf80 00000020
$20 : 80389140 00000014 00000000 2aac6358
$24 : 00000000 00000000
$28 : ef08e000 ef08fb90 7fbb4c80 8001d2dc
Hi : 00000280
Lo : 00000230
epc : 8001d2dc dma_map_single+0x88/0x134 Tainted: P
ra : 8001d2dc dma_map_single+0x88/0x134
Status: 10008b03 KERNEL EXL IE
Cause : 00800024
PrId : 0002a044
Modules linked in: dvb_as102 udf ext2 ntfs vfat fat sr_mod cdrom usb_storage cifs isofs fpga_directc brcmfb fb dvb_bcm7413 dvb_core procmk snd_pcm snd_timer snd_page_alloc snd soundcore firmware_class i2c_dev i2c_core evdev input sata_svw libata
Process usbtuner (pid: 729, threadinfo=ef08e000, task=ef09d0b8)
Stack : 80390000 a1fb8000 00000080 00000002 ef05bf80 827d2c00 803f2824 801f5e18
00000008 0000000a 80386570 803862b8 80387104 80392dc0 00000001 80040b80
803277b4 00040000 80390000 fffbffff 80387108 80066f68 10008b00 c0d76000
803a9c0c ffc00000 00400000 c0d75fff c0d76000 ef27e338 e01e7a80 80040d4c
ffc00000 00400000 c0d75fff c0d76000 c0cce000 80007fe0 eff4c704 c06f5f80
Call Trace:
[<8001d2dc>] dma_map_single+0x88/0x134
[<801f5e18>] hcd_submit_urb+0x1f0/0xa2c
[<c0489680>] as102_submit_urb_stream+0x68/0xe0 [dvb_as102]
[<c048973c>] as102_usb_start_stream+0x44/0x80 [dvb_as102]
[<c0487618>] as102_dvb_dmx_start_feed+0xac/0x174 [dvb_as102]
[<c0121418>] dmx_ts_feed_start_filtering+0x64/0x150 [dvb_core]
[<c011cf34>] dvb_dmxdev_start_feed+0xd4/0x158 [dvb_core]
[<c011ec20>] dvb_dmxdev_filter_start+0x310/0x4e8 [dvb_core]
[<c011f7ac>] dvb_demux_do_ioctl+0x2ec/0x760 [dvb_core]
[<c011c634>] dvb_usercopy+0x108/0x1f0 [dvb_core]
[<c011d9cc>] dvb_demux_ioctl+0x24/0x30 [dvb_core]
[<800be5b4>] do_ioctl+0xa4/0xb4
[<800be630>] vfs_ioctl+0x6c/0x3ac
[<800be9b4>] sys_ioctl+0x44/0xa0
[<80014118>] stack_done+0x20/0x3c
Code: 24846378 0c00df03 02202821 <0200000d> 00002821 02002021 8fbf001c 8fb10018 8fb00014
[LCD]: unknown cmd 0x1015
Thank you!
Cpu 1
Hi : 00000280
Lo : 00000230
Cause : 00800024
PrId : 0002a044
Call Trace:
Thank you!
