Vu+ Uno non riconosce tuner DTT Avermedia A835
dopo esserti collegato al box mediante telnet digiti dmesg, dai invio e poi ti esce una sbrodolata a video...
copi le ultime 50 righe della sbrodolata (possibilmente dove leggi dvb-usb , usb, it913x, mxl, tda ) e incolli quello che ti esce su questo thread
ma incollo dove di seguito? scusa ma ci siamo incagliati lì...
No anche cosi non va,ora io non sono a casa ma vedo di farti avere quello che hai chiesto
Sent from my LG-E900 using Board Express
Ecco il risultato della funzione di telnet:
brcmnand_read_id: CS0: dev_id=ecf10095
After: NandSelect=40000101, nandConfig=15142200
Found NAND flash on Chip Select 0, chipSize=128MB, usable size=128MB, base=0
brcmnand_scan: B4 nand_select = 40000101
brcmnand_scan: After nand_select = 40000101
page_shift=11, bbt_erase_shift=17, chip_shift=27, phys_erase_shift=17
Brcm NAND controller version = 3.2 NAND flash size 128MB @18000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
usb 2-1: new high speed USB device number 2 using ehci-brcm
Bad block table Bbt0 found at page 0000ffc0, version 0x01 for chip on CS0
Bad block table 1tbB found at page 0000ff80, version 0x01 for chip on CS0
nand_read_bbt: Bad block at 0x049e0000
Creating 8 MTD partitions on "brcmnand.0":
0x000000000000-0x000007200000 : "rootfs"
0x000007200000-0x000007600000 : "kernel"
0x000007600000-0x000007a00000 : "boot"
0x000007a00000-0x000007c00000 : "splash"
0x000007c00000-0x000007d00000 : "cfe"
0x000007d00000-0x000007d80000 : "mac"
0x000007d80000-0x000007e00000 : "env"
0x000007e00000-0x000007f00000 : "nvm"
UBI: attaching mtd0 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
scsi2 : usb-storage 2-1:1.0
ata2: SATA link down (SStatus 4 SControl 300)
UBI: max. sequence number: 466
UBI: attached mtd0 to ubi0
UBI: MTD device name: "rootfs"
UBI: MTD device size: 114 MiB
UBI: number of good PEBs: 911
UBI: number of bad PEBs: 1
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 911
UBI: number of PEBs reserved for bad PEB handling: 9
UBI: max/mean erase counter: 3/0
UBI: image sequence number: 134946940
UBI: background thread "ubi_bgt0d" started, PID 49
UBIFS: parse sync
UBIFS: recovery needed
UBIFS: recovery completed
UBIFS: mounted UBI device 0, volume 0, name "rootfs"
UBIFS: file system size: 112627712 bytes (109988 KiB, 107 MiB, 887 LEBs)
UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 0 bytes (0 KiB)
VFS: Mounted root (ubifs filesystem) on device 0:12.
Freeing unused kernel memory: 244k freed
NET: Registered protocol family 10
rtw driver version=v3.4.4_xxxx.20120730
Build at: Dec 3 2012 17:11:41
usbcore: registered new interface driver rtl8192cu
procmk_init
scsi 2:0:0:0: Direct-Access TOSHIBA External USB 3.0 0001 PQ: 0 ANSI: 6
sd 2:0:0:0: Attached scsi generic sg0 type 0
scsi: killing requests for dead queue
sd 2:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Mode Sense: 33 00 00 08
sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DP O or FUA
sda: sda1
sd 2:0:0:0: [sda] Attached SCSI disk
dvb_bcm7413: module license 'Proprietary' taints kernel.
Disabling lock debugging due to kernel taint
DVB: registering new adapter (vuuno)
enable MII = 0
Booted !
NEXUS_Frontend_GetUserParameters 0 0
bcm7413: hotplug_callback():
Hotplug - status.connected 1
Hotplug - connecting HDMI to display 0xe
[GPIO]Default
[GPIO]RST Default
[GPIO]fpga secu
[GP]:brcm_pwm_init
brcm_demux_init: $Id: bcm7335_demux.c,v 0.6 $
[VID]: <6>bcm7335_video_init
[AUD]: <6>bcm7335_audio_init
DVB: registering adapter 0 frontend 0 (Vuplus FE)...
bcm7413: bcm7335_frontend_init(): vtuner1 : 2
[MPVR]: >> misc_pvr_init
input: dreambox advanced remote control (native) as /devices/virtual/input/input 0
[LCD]: registered
[CI]:0 1
[CI]: registered ci0 0
[CI]: registered ci1 0
[DFP]: registered dbox fp
[DFP]: Scart 9597 is found 4
[SC]: registered sci0
[SC]: registered sci1
system_time_set wakeup mode get
system_time_set wakeup mode get 0xc4
fpga update driver loaded
udevd (107): /proc/107/oom_adj is deprecated, please use /proc/107/oom_score_adj instead.
usbcore: registered new interface driver uas
UDF-fs: No partition found (1)
NTFS volume version 3.1.
NTFS-fs error (device sda1): load_system_files(): $LogFile is not clean. Mounti ng read-only. Mount in Windows.
[VID]: VIDEO_SET_STREAMTYPE 0
[VID]: VIDEO_SELECT_SOURCE 1
[VID]: VIDEO_PLAY 1 2 0
[VID]: VIDEO_CONTINUE 1 1
[VID]: VIDEO_CLEAR_BUFFER 1 1 0
[VID]: VIDEO_STOP 0 1
[VID]: VIDEO_SELECT_SOURCE 0
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
svc: failed to register lockdv1 RPC service (errno 124).
[LCD]: unknown cmd 0x1015
[CI]:ci_dev_open
[CI]:entering.. A NEXUS_DvbCi_Open
[CI]:NEXUS_DvbCi_Open done..
[CI]:Installing callbacks
[CI]:Forcing card check
[CI]:Card insertion status changed
[CI]:entering.. B NEXUS_DvbCi_Open
[CI]:Card B insertion status changed
[CI]: CI interface initialised
[CI]:ci1_dev_open
[AUD]: AUDIO_SET_MUTE 0
[AUD]: AUDIO_SET_MIXER -838984208
[AUD]: AUDIO_SET_MIXER : amixl 0, amixr 0
[AUD]: AUDIO_SET_MIXER : next left volume 0, right volume 0
[AUD]: AUDIO_SET_MIXER : next left volume -70, right volume -70
[AUD]: AUDIO_SET_MIXER : amixl 7, amixr 7
[AUD]: AUDIO_SET_MIXER : next left volume -570, right volume -570
FE tune
dvb_demux_feed_del: feed not in list (type=0 state=0 pid=ffff)
[AUD]: AUDIO_SET_BYPASS_MODE 0
[AUD]: AC3 proc_get_ac3 0 audio_passthrough_spdif : 0
[AUD]: AUDIO_PAUSE 1
[AUD]: AUDIO_PLAY 1 decoder start : 0
[VID]: VIDEO_SET_STREAMTYPE 1
[VID]: VIDEO_FREEZE 1 0
[VID]: VIDEO_PLAY 1 5 2
[VID]: VIDEO_SLOWMOTION 0 1
[VID]: VIDEO_FAST_FORWARD 0 1
[AUD]: AUDIO_CONTINUE 1 1 audio pid_hndl : 0xe0db4d64
[AUD]: setting mute : 0
[AUD]: AUDIO_CHANNEL_SELECT 0
usb 1-2: new high speed USB device number 2 using ehci-brcm
WARNING: You are using an experimental version of the media stack.
As the driver is backported to an older kernel, it doesn't offer
enough quality for its usage in production.
Use it with care.
Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
Custom Black Hole build
Use it with care.
usbcore: registered new interface driver dvb_usb_it913x
it913x: Chip Version=01 Chip Type=9135
it913x: Remote propriety (raw) mode
it913x: Dual mode=0 Tuner Type=38
usb 1-2: dvb_usbv2: found a 'Avermedia A835B' in cold state
usb 1-2: dvb_usbv2: Did not find the firmware file 'dvb-usb-it9135-01.fw'. Pleas e see linux/Documentation/dvb/ for more details on firmware-problems. Status -2
usb 1-2: dvb_usbv2: 'Avermedia A835B' error while loading driver (-2)
usb 1-2: dvb_usbv2: 'Avermedia A835B' successfully deinitialized and disconnecte d
Alleluia!!!!!!! Funziona!!!!!! :yahoo:Grazie a tutti per l'aiuto nel risolvere questo problema,ne approfitto per augurarvi un Buon Natale. :thanks:
