Hi! I had the same problem with 0% signal strength showed the image and on weak transponders the signal jumped 75% -25% Express AM6 53E etc. On strong transponders 100% showed. Don't buy VU + Zero 4K I sold it too. Of course it's good that it doesn't have FBC tuner, FBC tuner always shows less signal strength 15-20%, if my old VU-SOLO2 shows 100% then FBC tuner shows 15-20% less
I did not fix this bug I bought Vu + Zero 4K in 2019 and this bug was already in 2018
Again with this nonsense about signal strength: as written by many people many many times, the signal values showed by a STB have no meaning: STBs are not measurement devices.
What matters is: can you watch those channels or not?
It is a mistake from the first day of this receiver, brand more, no matter, the tuner you have is good, in the end comparing several receivers and a real test of the Astra at 28'2ºThis one can not tune the UK beam in Spain.
In Spanish for me.
Es un error desde el primer dia de este receptor, marca de mas, no importa, el sintonizador que tiene, es bueno, al final coparacion de varios receptores y una prueba real del Astra a 28'2ºEste que no se puede sintonizar el haz UK en España.
En español para mi.
Astra a 19'2ºE Canal Sur A. (Andalucía) 11156 V 22000 5/6, 80cm, LNB de 0'5dB. VU+Zero4K tuner DVB-S2X
Señal/SNR 100% Calidad/AGC 99% VU+Solo2
Señal/SNR 100% Calidad/AGC 86% VU+Uno4K tuner DVB-S2
Señal/SNR 94% Calidad/AGC 65% VU+Uno4K tuner DVB-S2X (quality difference)
I deeply regret buying this device. The image pixelates, but it doesn't show this as BER. I can't tell if it's a signal issue or something else. I'm trying to watch Digitürk 4K channels using a module, but during transition scenes, there are mosaics. I thought it might be related to the module or overheating, but I noticed that similar issues occur on the FTA TRT 4K channel as well. I wish I had saved up a bit more and bought the Dreambox Two instead.
I've disconnected the Vu+ Zero 4K and hooked up my Vu+ Duo again. Now I'm watching 4K channels via streaming on Kodi.
Just like its name suggests, zero. 4K zero, 4K nothing!
