Vu+ Zero 4K Tested for You !!!
Nobody is forcing you to use BH or OBH (incidentally: have you tried OBH 4.1?).
If you like another image we are not going to blame you. But it's not appropriate to go to someone's home and criticise it or criticise the host.
Yes , after updates I have working usb DVB-T tuner (Based on the R820T tuner IC and RTL2832U)! Sorry, but the only good working image for me is OpenATV...
Sorry, but i don't understand what you stated, the R820T tuner IC and RTL2832U works on the original firmware or not? you are tell me that i will need to replace it with another firmware?
I tried all images but only on Openatv I have working DVB-T stick, normal 4,9E channels grabbing ( without not found SID in PAT), and used to me neutrino style remote (OK-channel list, up/down- channels up/down, left/right- volume left/right). Please make BH and OBH better !
Why do you need BH and OBH?
when you have an image that works for you without a problem ??
Had this box just over a week now everything works fine on every image i have triad also my cable usb dvb sky works on open blackhole and all others that have the right drivers great bit of kit for the price 139.99 delivered whats not to like
Finally i bought the Vu+ with the turbo dvb-t receiver... it works with the original image and from yesterday also with BH image.
I own both the DVB-S2X and the DVB-C/T2 version of the VU+Zero 4K. Bought the PVR-Kit as well. At the beginning a lot of problems with the internal cardslot and the CI slot. After the update from 15-03-2018 all these problems but one are gone. The DVB-S2X version somtimes returns 0% signal when zapping from transponder to another transponder. Obviously a DiseqC quirck. Boxes are very quick and can work with a load of plugins. Due to the PVR-kit recording/timeshifting works fine. My boxes run on VTi 13.0.9 since this is updated fastest. The VU+Zero 4K and PVR-kit looks very sleek.. Excellent receiver for the money. This box is going to be used in all my guestrooms.
Bought this after many Vu+ products (solo2, solose v2 x 2, Uno4k) and really like loving this so far, very nippy and stable.
One thing I would like to do is speak with Vu+ Team to ask if they can add plugin
STALKER-QT drivers/plugins (as used this on a Mutant HD51, and even zgemma h7/h9s has it0 but rumours are Vu+ not sorted the drivers for qt?
If any moderators on forum find out if this possible, would be very grateful. Please.
Thank You.
Hi,
Why would you like it not to work on USB ? Recording or timeshift will always work on USB.
You can even add a usb hub.
Flashing is straighforward. Grab a USB stick with only 1 partition (no hidden partitions like SanDisk U3). Format in FAT32 filesystem. Download your desired image for the VU+ Zero 4K. Unpack/extract DIRECTLY to your USB stick (which preserves the correct directory structure). Safely disconnect from PC. Turn off the VU+ Zero 4K completely (flip the switch on the back). Insert the USB stick in the VU+ Zero 4K. Turn the VU+ Zero 4K back on... Flashing will start automatically..
