Matrix10
1. Put the antenna,on the support at approximately 0 position.
2. Turn the antenna with your box to Zero sat (4.3 E ?)
3. Adjust the antenna for maximum signal.
( turning manually (mechanical) antenna rotor combined with manual adjustment antenna elevation on ZERO SAT 4.3 E ?)
4.Go to the extreme western and eastern satellites
5. Check signals.
6. If necessary, re-adjusted antenna on 4.3 E
7. If you have good signals on the Eastern and not Western satellite
(or vice versa) then the support pipe or antenna is not vertical.
8. Remember this is all accurate job
Abt VU+ Zero
Perfect working box for this money
5. Check signals.
Abt VU+ Zero
