Mito
If you have any problem with Ethernet on Zero, please update CFE.
If your set is working properly, PLEASE DO NOT UPDATE IT!
How to update the bootloader:
PS: This Bootloader (CFE) should be used for Zero only. Otherwise it will crash the box.
- Unzip the vuplus_zero_cfev1.04.zip to USB stick.(There should be /vuplus/zero/cfe_cfe_auto.bin)
 - Insert USB stick into the USB port of Zero and turn the power on.
 - It takes just a few seconds to update.
 - If front LED of Zero displays blinking, remove the USB stick and restart the box.
 - If the update of the Zero CFE has completed successfully, the LED will blink four times on reboot.
