vu+ zero plugin transcoding?
luis
hola
Do you know if vu+ zero has the plugin transcoding to streaming?
I know that vu+ solo2, duo2 and SE, support the plugin transcoding to streaming.
thanks
eugene73
Hi, I have a VU+ Zero I just want to be able to view on iPad on home network, I cannot view it on Vlc or the VU + App, I can see the box on the app and can edit bouquets but I can not see channel list or stream, this is probably something basic. (I can view web page if the Zero on port 80) any suggestions?
