VuCC VU+ Control Centre Version 0.2 Beta by Lee Hudson
>>Artorius<<
>>English Admin<<
A quick VuCC Video guide is available on Youtube
Installation Instructions
Unzip all the files and folders in the zip file to your local hard drive.
How to Use VUCC
1. Run the VUCC.exe application.
2. Enter the IP address of your Vu+ in the IP Address field, example 192.168.1.5
3. If you have changed the password on your receiver, enter the password in the password field
otherwise leave blank.
4. Click Connect Button
Telnet
Self explanatory.
For a list of Busybox commands check out the following website:
http://www.busybox.net/downloads/BusyBox.html
FTP
Click the FTP Button.
This will load FileZilla FTP Client and automatically connect to your Vu+
For instructions on using FileZilla check out the following website:
http://wiki.filezilla-project.org/Using
Settings Backup
Click on Settings Backup Button.
Click the Backup Settings Button.
This will backup all the settings from the Vu+ to the /enigma2 and /tuxbox folders on your PC HDD.
The /enigma2 and /tuxbox folders will be located in the same folder as this program.
Click the Restore Vu+ Settings Button.
All your backup data will be restored to the /etc/enigma2 and /etc/tuxbox folders on the Vu+
Once the files have successfully been restored you'll need to reboot the receiver by powering off
and on using the switch on the back of the receiver.
Media Files Manager
Uploading a Media File:
Select the Hard Drive and folder that contains your Media File.
Select the PVR device you have installed from the "Choose PVR Device" drop down window.
Click on the Local file you want to upload so it's highlighted in blue.
Click the Upload Button to transfer the file from your local HDD to the Vu+.
Downloading a Media File:
Select the Hard Drive and folder that you wish the file to be transferred too.
Click on the Remote file you want to download so it's highlighted in blue.
Click the Download Button to transfer the file from the Vu+ to your local HDD.
Deleting Local File:
Select Local file so it's highlighted in blue.
Click Delete Local File Button.
Deleting Remote File:
Select remote file so it's highlighted in blue.
Click Delete Remote File Button.
Vu+ HDD Manager
To mount and format a Hard Disk Drive do the following:
Select the receiver type and Hard Disk type.
Click the Format Button.
This will erase all the data on the Vu+ HDD.
Wait until the format has completed. It can take approx 10-15 minutes for a 1TB HDD.
You'll see a command prompt like the one below when the format has completed.
root@bm750>
Vu+ WebControl
Click the Vu+ WebControl Button to open Vu+ WebControl in your default web browser.
Upload Channel List
Select the local directory where the Channel List is sorted.
Double click the folder to list the files.
Click the "Upload Channel List" Button.
When you see the "Channel List Uploaded! Reboot Vu+" message box appear click OK.
Now Reboot Vu+ by powering off and on.
Kind Regards
Lee.
Released 30-9-2010
  • VuCC_V0.2.zip
willie martin
How to Use VUCC
Telnet
Self explanatory.
FTP
Settings Backup
Media Files Manager
Vu+ HDD Manager
root@bm750>
Vu+ WebControl
Upload Channel List
Kind Regards
Lee.
Released 30-9-2010
hi der im having problems wit vucc,wen i try going into web control it looks for a username and password which iv never set.any thing i can do
petine
After downloading I did unzip all the files and folders in the zip file to my local hard drive. Then I ran the VUCC.exe application. But ..........
But why is this programme only to be opened with DOS/Windows, while the Vu+ is a 100% Linux programme ??
I am using Ubuntu/Linux.
So what do I have to do now....
>>Artorius<<
>>English Admin<<
Make your own version.
petine
But please give me the solution, because I like to install this application.
Verstuurd vanaf mijn GT-I9100P met Tapatalk
abdus0161
My vu solo 2 has got red lights does not turn on after a software update can it be repaired if i take it to a satellite store!
jasjas
I am trying out the VU+ control centre (above) but get this error:
Vu+ Control Centre by Lee Hudson.
Access violation at address 00542856 in module 'VuCC.exe'. Read of address 00000000.
OK
I am connecting to a VU+ Duo2, and have no problems with the normal web interface via Firefox. Presently I have a sudden problem connecting via FTP (Filezilla - normally fine) and thought I would try your s/w (V0.2), but only get as far as this error from a Windows 7 x64 machine. Any suggestion as to cause? Maybe the FTP problem is causing this issue?
Many thanks
JS
jasjas
OK
Many thanks
JS
So sorry - looks like it was my mistake - I had a VPN client running which seemed to have blocked the FTP connection. All ok now (or at least I am connected). As ever, with all error messages ever displayed anywhere, the above "access violation" could be improved and made me think it was a more serious problem. A low priority!
Apologies, and thanks again
JS
Dragos
thanks
How to Use VUCC
Telnet
Self explanatory.
FTP
Settings Backup
Media Files Manager
Vu+ HDD Manager
root@bm750>
Vu+ WebControl
Upload Channel List
Kind Regards
Lee.
Released 30-9-2010
