Vuplus solo new bootloader
if you are reciver is stuck and doest not rebot in image than no need of new bootloader...just eject the rare hard disk from your vu plus solo 4k than try an image .... i tried and my problem is solved now i can add or remove images from my vu plus solo 4k .... try it it will work and pray for me thanks
This thread is 8 years old, and refers to the VU+ solo receiver.
VU+ makes quite a few receivers, including the VU+ Solo, VU+ Solo SE, VU+ Solo 2, and the VU+ Solo 4K.
And, also, @balosh , if your mother tongue is not English and you don't feel confident enough in this language to write in the International section, it is better to use an automatic translator (specifying you did so) because your message is almost impossible to understand.
