Waves
Waves 4 Fire Weather
Skin for weather in extra OSD
1. First you have to download and install from BH image server (green button)....BH plugins>>>Weather Plugin
2 Start Weather Plugin set your city and city code with Menu button/yellow button ....
3.Download and use this skin for Weather info in extra OSD (2 x OK button)
hello :p
im using Waves2 but i want to showing provider in the first infobar i dont want channel number pls can you edit that for me ??
hello :p
Unfortunately i do not make a special skin.xml for users
then do not end any of my skin editing.
When we release a new image you can edit it yourself again.
You have to edit self.
Replace in the skin.xml file in Waves2 folder( /usr/share/enigma2/Waves2/skin.xml ) this line.(use search in text editor ,search for ChannelNumber)
replace this
<widget source="session.CurrentService" render="ChannelNumber" position="65,24" size="220,50" font="Regular;36" foregroundColor="#ffffff" backgroundColor="#10000000" halign="center" transparent="1"/>
with this line
<widget source="session.CurrentService" render="Label" position="65,16" size="220,60" font="Regular;22" foregroundColor="#ffffff" backgroundColor="#10000000" valign="center" halign="center" transparent="1">
<convert type="ServiceName">Provider</convert>
</widget>
Use the appropriate editor
for example, a simple, free, good editor
https://www.editpadlite.com/download.html
replace this
with this line
</widget>
ok sir thanks for your help
in Waves2 i solve it............ but in skin_default i dont find that line + i found 2 skin.xml
1-skin.xml
2- skin_default.xml
